A little help, please
This is a recent problem. I keep getting this every time I install new content. Most of it installs fine but there are several items with these price tag icons with Daz Premier logos which won't install. There seems to to be some issue with install location errors but I'm unable to specify the location. The drop-down isn't active.
I'm wondering if it's because I use external drives for my Daz content so the install location is different than the content directory. Studio is on my iMac's hard drive but my content is on an external drive.
IDK. Any advice would be appreciated.
1816 x 1482 - 190K
1688 x 2070 - 183K
  • crosswindcrosswind Posts: 10,357
    Check in Advanced Settings... > Applications tab, if the application paths of DS General Release and Public Build are correctly set.
  • I have the same problem.
    I have not changed from the default installation settings.
    It works fine except for this premier content.
    1903 x 1370 - 412K
    Publishing Build and Private Build are wrongly pushed to the users. You can delete them then ignore or hide them in Ready to Download tab.
    If you don't use Public Build, do the same.
  • crashworshipcrashworship Posts: 252
    edited October 2024
    Okay, color me officially confused. I've changed nothing relative to downloads and installation. It seems that DIM has two installation paths designated pointing to the same location on my hard drive. Also, I'm only designating downloads and installation for the current Studio release.
    2272 x 1588 - 248K
    2200 x 1708 - 259K
    1330 x 2098 - 164K
    Post edited by crashworship on
