Deleting DIM downloaded install packages ...
I have 1200 install packages saved by DIM after they were installed.  I want to remove them to make space on my C: drive.
Q: Is there a way to safely delete those old packages without uninstalling all content through DIM, then setting the delete after installation toggle on, then re-installing all content?
  • namffuaknamffuak Posts: 4,519
    In the installed tab, select the products you want to delete. Then right-click and select 'delete all selected'. It might pay to make a copy to an external drive - if you do uninstall at a later date you'd need to re-downlaod otherwise.
    That's probably the easiest way...
  • thrain9thrain9 Posts: 108
    Thanks for the info. copying to a thumb drive or alt storage is a very good idea.
    Many items I use I do Not want to delete, I just want to get rid of the install file download.  Those are in a file somewhere in the DIM folder, rather than DAZ Studio folders.
    Selecting and right clicking will bring up a context menu...Delete Packages will just delete the downloaded install package.
