Can I render earlier generations with the new toon settings?
Drogo Nazhur
[Can I render earlier generations with the new toon settings?] Or, do I need to change the shadings on everything? Also, what render options do I pick to get these toon effects in my renders?
You would need to apply the Filatoon shader, though not every surface will benefit and properties may well need tweaking - there is nothing tying the use of Filatoon to particular figures.
Check these threads for tips on using Filatoon:
https://www.daz3d.com/forums/discussion/704951/anime-toons-and-filatoon-shader-q-a/p1
https://www.daz3d.com/forums/discussion/704931/filatoon-cell-shaded-rendering-with-filament/p1
thank you
