Troubleshooting Weird Performance Issue with DAZ Studio 4.23
I am having a truly weird performance issue with 4.23.0.1 (System: Windows 11, AMD Ryzen 9 5950X, 64GB RAM, NVIDIA 3090).
When I start DAZ, I see an almost 5 minute delay in the startup where nothing is logged:
2024-10-21 18:57:33.762 [INFO] :: Creating Action Manager...
2024-10-21 18:57:33.771 [WARNING] :: Object::connect: No such slot ABFluidosCompanionAction::handleInterfaceColorsChanged() in abFluidosCompanion.cpp:57
2024-10-21 18:57:33.771 [WARNING] :: Object::connect: (sender name: 'Style')
2024-10-21 18:57:33.771 [WARNING] :: Object::connect: (receiver name: 'EditAction')
2024-10-21 18:57:33.780 [WARNING] :: Object::connect: No such slot UVTailorPaneAction::onInterfaceColorsChanged() in UVTailorPane.cpp:61
2024-10-21 18:57:33.780 [WARNING] :: Object::connect: (sender name: 'Style')
2024-10-21 18:57:33.780 [WARNING] :: Object::connect: (receiver name: 'DzAction')
2024-10-21 18:57:33.781 [INFO] :: Creating Pane Manager...
2024-10-21 18:57:33.938 [INFO] :: Successfully created OpenGL viewport for AuxViewportView.
2024-10-21 19:02:04.840 [WARNING] :: QFSFileEngine::open: No file name specified <--- 4.5 minute delay here!!!
2024-10-21 19:02:04.840 [DEBUG] :: Unable to open log file for writing: "No file name specified"
2024-10-21 19:02:04.860 [WARNING] :: QLayout: Attempting to add QLayout "" to USCTreeWidget "", which already has a layout
2024-10-21 19:02:04.863 [WARNING] :: QLayout: Attempting to add QLayout "" to USCTreeWidget "", which already has a layout
2024-10-21 19:02:05.400 [WARNING] :: QWidget::setLayout: Attempting to set QLayout "" on DzRenderQueuePaneWidget "RenderQueueSubPaneMainWgt", which already has a layout
2024-10-21 19:02:05.409 [WARNING] :: QWidget::setLayout: Attempting to set QLayout "" on DzDforceManageWidget "DForceManageSubPaneMainWgt", which already has a layout
2024-10-21 19:02:05.417 [WARNING] :: QWidget::setLayout: Attempting to set QLayout "" on DzModifierStackWidget "ActiveModifiersSubPaneMainWgt", which already has a layout
2024-10-21 19:02:05.444 [INFO] :: RenderQueue: we_restarted_DS: FALSE
Furthermore, whenever I touch the render editor pane (with iRay enabled), or do an iRay render, I see a similar extremely long delay which is REALLY impacting my productivity.
I have tried, as it did look like it only happened when I touched NVIDIA code:
- Upgrading the drivers (currently running studio 565.90)
- Uninstalling, cleaning out everything I could, and reinstalling DAZ and my entire content library
- Upgrading the driver with a clean install
Nothing worked. If anyone could advise on how to troubeshoot this better, I'd love suggestions. Thank you/
People have reported problems with the latest NVIDIA driver. Try rolling back to a previous version.
https://www.daz3d.com/forums/discussion/706511/daz-4-23-update-broke-iray-rendering#latest
Thanks, will try.
Wow - yeah, that was it.
Thank you! The load time went down to under a minute, running drivers 561.09.
It seems often to be best to stick close to the minimum required driver version, assuming nothing else on your system requires a newer driver.
