"Clear Wishlist" doesn't work
pixelquackpixelquack Posts: 417
edited October 2024 in The Commons
To whom it may concern, I had a great desire to use it concluding what I think of "exclusive Premier features that you cannot regularly buy on the shop anymore"
  • Moved to the Commoins as it is not a Daz Studio application topic.
    There are already plenty of discussion of Premier, no need for another. On the topic of the link, are you refreshing the page? It worked - in my test account, with a one-item wishlist - when I did so, which is also true of removing items one by one - the remove command greys and shrinks the thumbnail but doesn't actually complete the removal unless that page is reloaded (I don't know if that would require doing each page of a long wishlist separately).
  • Does not work for 800+ items. Seems looping over 1 item is a weight the server code can lift but gets stuck in whatever memory occupancy clearing 800 causes.
  • I can't clear even one item.  I try clear all 172 and it won't work either.
    Did you refresh the page?
  • Yes, I did.  I even added everything to my basket ($4000 worth :) ) and it still didn't clear it.
  • Adding to cart isn't meant to remove from Wishlist, so you can change your mind without having to fiddle.
    Have you tried a different browser? Does the thumbnail shrink when you click on the heart to remove it?
  • Yes the thumbnail shrinks and shades slightly.  I will try another browser (thanks for your help btw)
  • I tried Edge, Firefox and Google and it didn't work :(
    and then you refreshed the page while it was in that state?
  • Yes, it just refreshes back to the full wishlist.  I will try that in all my browsers.
  • I tried removing individually in Firefox, edge and chrome.  clicking on the little heart and then refreshing to no avail.  It's the same on another computer of mine as well.  Can other people use the 'clear wishlist items' okay?
  • It works, on a test using one item, for me.
  • frank0314frank0314 Posts: 15,093
    Try clearing your cache and refresh.
  • Sadly clearing the cache didn't work either.  I guess I am stuck with it :(
  • NylonGirlNylonGirl Posts: 2,360
    Maybe try buying all $4,000 of the items and see if that solves the problem.
  • mindsongmindsong Posts: 1,788
    clearing my wishlist hasn't worked for me for years - seriously. some single deletes work with a delay (kind of grey out for a long time), but the clear the whole thing option has never worked for me. tried many times since it appeared.
    I cynically assumed it was a 'feature' for Daz... and low on the fixit list, if there at all.
    If only a few of us see it, perhaps it might be an account-specific settings phenomena. Stranger things have happened with the website.
    cheers,
    --ms
