Save out - maybe a mistunderstanding
cosmo71cosmo71 Posts: 3,609
Hello, someone wrote me on a question I had, that I can save the props out. Does this mean that there is a option that makes it possible to save a prop in a scene out as a single scene without closing the scene I am just working on?
    No, you select the prop and then File > Save  As > Support Asset > Figure/Prop Asset.  This saves it as an actual prop asset.
    You could also select a prop or series of props and File > Save As > Scene Subset.  This works well for  groups  of things that will then be loadable as a group.  You don't need to merge the scene subset, as it will load without overwriting your current scene, like loading a new scene does.
  • cosmo71cosmo71 Posts: 3,609
    ah okay, thank you for the information :)
