Discovered an issue with applying textures on older figures
Does 4.9 not differentiate older Genesis figures with its textures? I can no longer use 4th gen textures on Genesis, it simply won't apply the texture even though I have the UVs for them. Also, when using anatomical figures on G2 and older figures, it applies to the main body, not to the genitals. So we have to now manually apply these textures to these figures that are not Gen 3?
    Are you talking about Genesis or Genesis 2?  I'm not having any trouble applying V4 textures to Genesis in DS4.9.
  • BanbhaBanbha Posts: 12
    To Genesis 2. In fact, I'm also not able to get Iray to apply to the genital hips so I can convert the shaders for Iray optimization. Before 4.9, I was able to do this.
    Are the textures in .duf format?  To apply V4 texturres to G2 they need to be .duf.
    Yes they are. In fact the libraries haven't changed at all from before I upgraded to 4.9. After I got 4.9, the textures and UVs just don't want to load from a preset. Wanting to set Iray to genitals are also not working the way they used to before. I can't even apply from a preset to the genitals because it applies to the body instead.
    Is this the general release or the public build (beta)?
