where is Measure Metrics hiding
XaatXuun
in The Commons
I looked in windows pane, and there is no Measure metrics to select.
from the doc page http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/plugins/measure_metrics/installation/start
Summary
In order to use the Measure Metrics plugin, you must first have DAZ Studio 4.6 (or higher) installed. This plugin will not load in versions of DAZ Studio prior to 4.6.
and I am using 4.6
You mean the product?
http://www.daz3d.com/measure-metrics-for-daz-studio
I looked in plugins and there is no measure metrics to add the serial #
is it under different name ?
yes that one, I have installed it 3 times still nothing, and it is going into the right directory
Measure Metrics is a plug-in that is tied to the current version. To use it with 4.6xx, you'll need to contact support about getting the version for the exact version of DS you are using.
okay, thanks
seems a bit messed up to me to do that. . maybe they should change the Doc page too.
just one more question, will I still be able to get 4.8, I don't like what I read about 4.9 so far
getting a new computer in the next couple days, was going to keep 4.6 on this one, and place 4.8 on the new one
You'd need to ask Support for anything other than the latest version.
maybe I should just contact Support, before making any future purchases.
Need to contact Suppport after each order anyways, that could speed up the process at least
