G8 Expressions on G8.1
I've been using the method of removing the Base Pose Head and Expressions from the 8_1 Morphs folder successfully for the last 2.5(?) years to use G8 expressions on my 8.1 models. Every time there was a studio update, I'd have to repeat the process, but everything still worked fine. This time around it doesn't work. I'm not sure if it's a 4.21 issue or something else, maybe things got moved around. Is anyone else having this problem or have any solutions?
  • crosswindcrosswind Posts: 10,300
    There was no such an issue on my side, even on the latest 4.23. The way of removing / archiving those two sub-folders always works... up to now.
  • HoppyHoppy Posts: 1
    Solved! I sort of figured it out but am not sure how this even happened. I've been going into the usual set of files and making the changes there (as I have the other fifty times I've done this) and nothing was changing. After some digging around, my studio is now using a completely different file location to draw the 8.1 files from. I've no idea how they got there or why the path changed, but at least I've got it figured out.
    ...unless you have several copies of Starter Essentials installed in different Daz Libraries... or installed another copy via Daz Connect ...
