Gen 8 updater will not install
I have been trying to install the Genesis 8 update. It gets to 72% complete then fails. I have included the log file. Can someone explain to me what's the problem? Thank you.
txt
txt
Gen 8 install log.txt
248K
  • crosswindcrosswind Posts: 10,343
    It seems a syntax issue + uncompress issue with package ZIP file.
    You can stop installation, totally delete G8 Starter Essentials packages in DIM > Ready to Install tab, then redownload them. Then retry.
  • Thanks for the input. I did as you suggested, several times and I'm still getting the same problem. surprise
    txt
    txt
    gen 8 LOG 2.txt
    200K
    edited October 2024
    Same error there... nothing changed. You can try another way: manually extract the content folders from IM package (under Content folder !) files to your Daz Library root directory. Then re-import metadata to cms database.
    If there's an uncompressing error or sth., it means your IM packages are really corrupt ~~
    Post edited by crosswind on
  • I think that fixed it. Thank you very much!
