Where can i find the filatoon shader
Hi,
I have been seeing and reading alot about the filatoon shader. I have updated to 4.23...I see some toon characters in the basic but nothing that is called a filatoon shader.
I also looked in the directory but nothing is there.
Anyone that would know the solution/?
Thanks.
  • A lot of information in this thread, including where the shader should be by default and what needs to be downloaded for this: https://www.daz3d.com/forums/discussion/704951/anime-toons-and-filatoon-shader-q-a/p1
  • 3Diva3Diva Posts: 12,058
    You should be able to find the shaders under: Shader Presets >> FilaToon. There are a couple of other places to find the FilaToon Anime characters and environment settings, so I recommend checking out that thread that has been linked.
  • joannajoanna Posts: 2,823
    In Smart Content, it's going to be under Shaders->Filament, and you should see Daz Default Resources there. If there are no toon shaders there, uninstall and reinstall Daz Default Resources.
