Hunter's moon bugged ?
Could someone confirm this product has become incompatible with the latest DS version (4.23) ? Any props I try to import into my scene, it displays an error message with a list of missing files, like this :
https://www.daz3d.com/hunter-s-moon
  • LeanaLeana Posts: 13,650
    Hunter's moon is a set of textures for various products (Millennium Environment, the Multiplane Cyclorama and the Woodland Realm Playsets).
    Do you have those installed?
  • linoge8888linoge8888 Posts: 102
    edited October 2024
    There is a note : "While this texture set can be used on its own..." and I don't see any required products to install beforehand on the page. Well, I feel fooled. RIP my money.
    Post edited by linoge8888 on
  • ElorElor Posts: 4,255
    You can ask for a refund if you bought that product less than 30 days ago:
    https://bugs.daz3d.com/hc/en-us/articles/115003500163-What-is-Daz-3D-refund-policy
    There should have been requirements but they somehow disappeared, I reported it. The required products are also Daz+ items.
    As Elor said, you can get a refund.
  • Richard HaseltineRichard Haseltine Posts: 111,996
    edited October 2024
    You can in fact apply the maps to primitives - they are pretty simple - and use those instead of one of the required products. I just spent ten minutes fiddling with a cylinder primitive,  using the Geometry Editor to split it into materials, applying the maps by dragging them onto the Base Colour in the Surfaces pane Editor tab (and so far not adjusting other settings) and tweaking the tiling values to get them to line up. Using planes would have been even easier, buth then you would have to positiona dns cale them relative to each other. Of course you may not want to do all of that, in which case yes get a refund.
    966 x 964 - 90K
