Saving Morph Assets has disappeared from DAZ 4.23.0.1 (64-bit)
mlominymlominy Posts: 227
Trying to save a morph I just made by using the usual procedure.
Saving as Morph Asset(s) is not accessible anymore.
Is the functionnality still there? If not, major setback!
924 x 796 - 171K
Post edited by mlominy on
  • crosswindcrosswind Posts: 10,343
    It's changed to Save Modifier Asset(s).
  • mlominymlominy Posts: 227
    Thanks Crosswind. Worked like a charm....
  • I have had the same problem. And I can't add dForce either. I can run DFoce itself. Some of my menu has also disappeared. The update is very problematic. Is this version even a Pro version? Despite being registered, it only shows version 4.23 not 4.23 Pro.
  • neomanneoman Posts: 85
    Update your drivers... I'm guessing that is your problem with DForce.
    DS no longer shows Pro, only Premier gets noted in the title bar - along with the release  channel if it isn't a General Release
    http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log_4_23_0_1#4_22_1_230
    If you have the content creation tools in the Tool menu (Geometry Editor, Node Weightmap Brush etc.) then it is still the Pro version.
  • J'essaie de sauver un morphe que je viens de faire en utilisant la procédure habituelle.
    L'épargne en tant que Biens Morph n'est plus accessible.
    La fonctionnalité est-elle toujours là ? Si ce n'est pas le cas, un revers majeur
  • felisfelis Posts: 6,583
    Use File > Save as > Support asset > Modifier asset.
  • faibolxfaibolx Posts: 78
    Thank you! I was confused and your answer helped me a lot
