Is there's a script that can scan a library and all moved folders and repair the database?
Is there's a script that can scan a library and all moved folders and repair the database for each path?
  • crosswindcrosswind Posts: 10,330
    I guess that the things in your Smart Content are messy, because you've moved or reorganized the folders of Content assets either in Content Library or File Browser, correct? AFAIK, there's no such a script. In my experience, technically it can be fixed by a script or a program but it'll be pretty difficult to repair metadata in cms database in this case...
  • woyodowoyodo Posts: 37
    I find a option called Update Metadata in Help & login in menu.Is it works?
    Oh, no, Update Metadata has nothing to do with OP's case and it may bring other unexpected issues as per the existing metadata in cms database. So be careful when using this function.
    Lucky to see your reply before I use it
