Can having a lighter coloured (paper roll) background make rendering take longer?
So as a lighter coloured background creates more light will it contribute to increasing render times?
    I haven't seen that effect.
  • XoechZXoechZ Posts: 1,102
    I think more important than the color is the glossiness. If your backdrop is very glossy and therefore reflects a lot of light that falls back on your figure or whatever, than the render could be slower than with a matte background that does not reflect light. But this is just guessing, I am not sure about this.
  • DAZ_SpookyDAZ_Spooky Posts: 3,100
    Iray vs. 3Delight. Iray more light sources, to include reflectors, generally means faster render times. 3Delight more lights, and especially reflected light, means longer render times.
  • DestinysGardenDestinysGarden Posts: 2,553
    edited January 2016
    I have not noticed any increase in render times depending on the background color either. Having a bump and normal map on the backdrop can really increase it, depending on the other lights, as the renderer has to calculate all the little shadows on the backdrop.
    Post edited by DestinysGarden on
    I cant speak for 3Delight or Iray, because I am a Reality/Lux user. But from there I know that when I use a paperroll backdrop and set the material to "glossy", the render takes more time to clear up than when I set the material to "matte". This is because the render engine has more calculations to do, no matter how many light sources I use. The difference is not dramatical but definitely noteable.
    And, as DestinysGarden said, if the backdrop contains some bump/displacement, there are even more calculations to do for the render engine.
    Now, going back to the initial question, my experience is that the material settings of a backdrop have more influence on render times than its color. So, if you use a medium glossy backdrop there should not be a difference if it is light grey, dark gray, blue, red or whatever.
  • Thanks for the info guys
