UI Customization - Change Start Folder in Content Library
DopeFusionDopeFusion Posts: 25
I apologize if this has been discussed before, but a Google search didn't give me the answer I was seeking (possibly because I couldn't concisely articulate my query), so I thought I'd start a new thread.
Take a look at the image I've attached. I am wondering if I can customize my UI so that the folders listed first are the main library folders, rather than opening with the DAZ Studio Formats-->Daz3D Content-->Content. The folder "Daz3D Content" is a custom-named folder and it is not in the same directory as the D|S program, if that matters.
Basically, I do not want those first two columns showing at all. I'd like the first column that shows on the far left is the column containing the Animals, Applications, Documentation, etc. I do not need the Poser Formats or Other Import Formats because I have put them in the main area just for simplicity sake. Is there a way to set up my UI so they do not show?
EDIT: Also, while I have your attention, is there a way to make all of the text in the Daz Studio program just a little bigger? My eyes aren't as good as they used to be. :-\
776 x 434 - 121K
Post edited by DopeFusion on
  • crosswindcrosswind Posts: 10,357
    No, you have no way to customize that... as it's one of cons of using View as List, i.e. Formats / Content occupy two columes. You may consider using View as Tree.
    As for text size, try tweaking DPI settings for DS application ~
    You mean in Windows?
