Vue packages with Vue 2015
I have four Packges desgned for use with Vue 11 and lower.  The current version of Vue is Vue 2015.  The Install Manager complains about a mising path definiion for Vue 2014.  Setting the path to the Vue 2015 fails.  Is there a way to correct this? Thanks.
  • Are you setting the application to Vue and then the path to the 2015 installation? Is it failing in DIM or in Vue?
  • Exactly, application Vue's path set to 2015 installation. Fails in DIM claiming it cannot read find the required path.
  • fixmypcmikefixmypcmike Posts: 19,718
    If you open the manifest.dsx file in the product zip, there should be a line reading something like:
    <File TARGET="Application" VERSION="2015;2014" ACTION="Install" TYPE="Vue" VALUE="...">
    Whqat does it list under Version?
  • I download Vue packages manually. Works well. Just go into your Product Library and download it and open it. If its a vob or an atmosphere, just put it in the correct area in Vue Content wherever you store your Vue content. It's easier than trying to use DIM for Vue products.
