Questions about [ Iray Light Volume Kit ]
I would like to ask you about a product, Iray Light Volume Kit, which comes from KindredArts, an author I like very much.
This is a product to add VDB noise to the scene, but I felt that the scene did not change before and after use, no matter how to adjust the value, I could not see the change in the publicity map.
DAZ is there anything about the VDB switch? No effect if you don't open it?
  • Which version of Daz Studio? Are you doing a full Iray render?
  • kyoreonakyoreona Posts: 222
    the newest version of crouse...
    full iray render ? what do you mean "full" ?surprise
  • A render, not the nVidia Iray drawstyle in the Viewport.
  • jjoynerjjoyner Posts: 886
    I am a long-time dabbler at this stuff and by no means an expert.  Like almost everything else, the Iray Light Volume Kit takes a bit of fiddling and experimentation to get it to suit you desires for a scene.  I loaded a warehouse environment and the Iray Light Volume Kit and used Daz Studio’s Sun-Sky Environment Mode for lighting.  I used Iray Light Volume Kit’s Plain Room Volume with the Tint Orange material applied to it.  I could see a change in the Iray Viewport with and without the Iray Light Volume Kit in use.  Attached are rough renders of the scene with and without Iray Light Volume Kit in use.
    I’m using Daz Studio 4.21.0.5 on a Windows 10 laptop with 16 Gb RAM and an RTX 2060 card with 6 Gb VRAM.
    891 x 872 - 1M
    891 x 872 - 1M
    Thank you. It seems so simply but I try so many times and there is no effect. Maybe it's my render time is not enough. I will try again. Thank you
