How should I fix this morph that cannot wear shoes properly
liyanjifengliyanjifeng Posts: 3
I have obtained an unofficial homemade G8F foot morph, it seems that the vendor did not make a joint correction when sculpting feet, and keep the feet at a downward tilt angle as a whole, even though I used the 'adjust rigging to shape' function, the character's feet still couldn't put on the shoes properly. After I used the 'adjust rigging to shape' function, it can be seen that the character's foot rigging has not fully matched the model, I inquired with the vendor about this matter, the vendor said "For the shoes issue, since almost all the foot morph for daz are meant for showing barefoot only, my foot morph are aim to make the soles and toes looks more fantasy, so some shoes might not fit on the feet."
Obviously, the vendor's technical skills are unable to solve this problem, but I don't want to give up on this morph, I look forward to knowing how to make these feet wear shoes properly, even if it requires payment.
https://imgbox.com/keHHNnJU
https://imgbox.com/6MbCTNID
https://imgbox.com/jQ5JkbYI
Post edited by liyanjifeng on
  • ElorElor Posts: 4,100
    I have no idea how to fix your rigging problem but if most of the poke-through are happening on the sole of each feet, you can use a function that'll automatically hide chosen polygon when an item is fitted to the figure (it's explained in the second half of the video):
     The toes of the shoes are also deformed.
  • crosswindcrosswind Posts: 10,249
    edited September 2024
    Okay, almost everything can be fixed in Daz Studio... In this case, you just need to fix the PBM (partial body morph) on AS8 high heels... though I agree with that vendor to some extent devil.
    But yes, wearing peeptoe high heel shoes is totally different from wearing boots / sneakers yada yada ~~ you have "nothing to hide" ~ as well as the distortions are always there unless you fix them.
    Well, this foot morph looks strange... so after you dialed this morph, the figure's feet bent ?
    Post edited by crosswind on
