Is it possible to filter shape morph of one vendor only in shape pane?
  • crosswindcrosswind Posts: 10,249
    edited September 2024
    Yes... as long as there's a vendor's keyword in the Labels of morph properties. Then directly filter by the keyword or use a Regular Expression to filter.
    If there's no vendor's keyword in the Labels, you can batch edit DSF files to insert a keyword into Labels by using Notepad++... But that's just a workaround... as any product update may spoil what you've modified.
    Post edited by crosswind on
  • Also check the tags - if you find one by the vendor in question, expand the bottom panel of Smart Content (if it isn't), go to the tabs tab, and click the vendor name (if present) - that should populate the filter field to search for the vendor.
