Restore hidden toolbar in DAZ Studio
How do I restore the toolbar (the one with undo and redo buttons just below the menu bar) in Daz Studio 4.9 after I hide them. I hid it while trying to maximize my workspace and now I cannot get it back.
Reloading the layout did not help.
  • IceCrMnIceCrMn Posts: 2,334
    edited January 2016
    Press F3 or on the main toobar click "Windows>workspace>customize"
    On the right side pane, Click the tab labeled "Activities"
    expand the entry makered "Advanced" and then expand "toolbars" under that.
    Right click the entry marked "main" to enable or disable those tools.
    Click "apply" This will make the screen flicker as it readjusts the UI.
    Click "accept" to close the setting pane.
    Hope this helps
    edit: to clarify and add screenshot
    1920 x 1080 - 274K
    Post edited by IceCrMn on
  • Yes. That helped. The undo and redo actions were in the input output activities set though.
  • MarshianMarshian Posts: 1,465
    Thanks so much! I kind of short circuited when I couldn't find it.
  • Thanks a lot! That looks rather counter intuitive, but once known, this trick is great ! wink
  • I used it for a while but now it's not working at all on my system. I'm using Daz Studio Pro version 4.10.0.123 and I ttried reinstalling and tried the toolbar but it is not showing up at all.
    I'm on Mac High Sierra.
  • Richard HaseltineRichard Haseltine Posts: 111,908
    So it's enabled if you right-click on the tool bar in the Activities tab in Window>Workspace>Customise?
  • dougdoug Posts: 14
    edited March 2024
    Hope this helps
    Thank you!! Been struggling with this I had tools listed as in the toolbar but werre hidden, but this brought them back... The disappeared after that last update.
    Post edited by doug on
  • barbultbarbult Posts: 27,648
    After a Daz Studio update it is always recommended that you run the Update and Merge Menus command.
  • Thanks a lot ^^
