difference between wheight and heavy morph?
cosmo71
What is the difference between wheight and heavy morph on G3F?. I know that if I change wheight the heavy morphs gets also changed, but if I just change the heavy morph it looks the same as changing the wheight morph, so what does the wjeight morphs does next to changing the heavy morphs?
wheight 10 = heavy 10 = result X
weight 0 and heavy 10 = result X
both is the same, so what shall the wheight morph?
Post edited by cosmo71 on
sorry , wrong forum
Moved to Tech Help
Try turning the Weight down below zero — you'll find that it also controls the Thin dial. A neat trick, I always thought. Note that the Weight dial on the Genesis2 figures also does this, it isn't new.
