Genesis 1 figures
This has been an issue for years all my genesis figures have a Genesis Crainal Ridge center morph at 100%I have uninstalled and re installed genesis many times did I not correct the problem do I have to uninstall the morphs I haven't tried that, now I just change the morph to 0% and lock it every time I use Genesis
    Something was saved with it at 100%, probably some character. So you need to figure out which it is and remove it or resave it with the ridge turned off (0%).
  • Look under Currently Used in the parameters pane to see which morphs are set to on, click the gear icon on the slider and then Parameter Settings to get the dialogue in which you change the default value, then File>Save as>Support Assets>Modified Assets and make sure that the morph is the only thing selected.
  • BejaymacBejaymac Posts: 2,012
    With Genesis in 4.6+ it wont be, the main Genesis asset file always shows up in there now.
  • Thank you for all the help none of it helped even saved Genesis with morphs at 0% as the main DUF and I  set Parameter Settings default to 0% ,Still Genesis showes up with the Genesis Crainal Ridge center morph at 100% but when I click default it goes to 0% so I'll live with that for now!
