What Skin Texture Did I Use? DS 4.8
When I create a scene and then come back to it later, I can never figure out which skin texture I used on a Genesis 2 or other figures.  Makes changing things like makeup difficult.  Is there anyway to tell which one you used?  I imagine you'd look in the surfaces pane, but I can never figure where it says it.
Thanks.
  • Oso3DOso3D Posts: 15,125
    If you click on one of the texture maps in the surfaces you clicked, it should show you the list of textures used in your scene (so that you can change it if you want). This might give you enough information.
    If not, you can click and hit Browse, which should take you to the folder that texture map is in, and the directory should give you a larger hint as to what you are doing.
  • onimushaonimusha Posts: 210
    Thanks for the fast answer.
