Group with a Group node or a Null node in DAZ
Could someone tell me the differences between grouping objects, lights, cameras, etc., elements of the scene, under a group or null node. The only difference I've found is that with null you can make the crosshead invisible in the viewport or make the node invisible in the viewport, and the related elements are still visible. With a group node, if you make it invisible, the related elements become invisible.
  • LeanaLeana Posts: 13,650
    edited September 2024
    Another useful feature of using nulls is that if you parent them to a null you can then use it to rotate all items around where the null is.
    Post edited by Leana on
  • iaunpomiaunpom Posts: 101
    Isn't it the same with parent  in a node group?
    Yes, but IIRC you don't choose where the parent ends up when creating a group, DS automatically creates it. With a null you can decide where it is more easily.
  • ZiconZicon Posts: 400
    Groups have the advantage that visibility settings applied to the group also applies to every member in the group. Very useful for quickly toggling visibilty while working on different parts of the scene, or removing a whole set from dforce simulations. Groups can also be turned into lightweight placeholders with Placeholder Manager or used as a source for Ultrascatter.
    And of course, there's nothing preventing you from using both: Group your items, then parent the group to a null.
  • Cmd/ctrl clicking on the eye next to a Null will also hide all of its children.
    They share that characteristic, but when null you can make it invisible by clicking on the eye without cmd/ctr the related elements are visible. If I do the same with a group node, the related elements are hidden in the viewport, without clicking cmd/ctr
    I have not understood this explanation, is it an important feature?
  • crosswindcrosswind Posts: 10,356
    Both of them have pros & cons...
    - Null node cannot auto-parent the selected items to it, you have to manually parent them. Group node, as default, auto-parent items selected.
    - If you Ctrl + Hide a Null Node, you still can individually unhide any sub-node of it. But if you hide a Group node, then any sub-node cannot be unhide individually.
    - Transforms of a newly-created Group node will be recalculated when grouping items(s), while with default settings, a newly created Null node just locates at world center...
    So, just use them as per your case and need.
    and, as I was reminded, if you ctrl-click to unhide the Null all of its children will become visible, even if some were originally hidden.
    Yep, exactly ~ Group node doesn't have such a behavior ~
    Thanks !
