Best converters for G9 to use G8F assets?
Hi. I'm interested in using G9 figures more, and I know there are several products to use for this, but I'm finding them a little confusing, or unsure if they're comprehensive, which ones are best for what kind of conversions (clothes, shapes, mats), that kind of thing. I don't want to waste purchases if I can avoid it.
Chiefly I'm looking to have G9s wear G8F clothes and hair, so I'd appreciate hearing what works best for that.
Past that, I am interested in shape and mat transfers, where G9 and G8 can swap interchangeably, so if there is a 'jack of all trades' conversion, that might be better to pick up too.
Thank you.
There's no converter which would convert everything from G8 to G9 and vice-versa.
Clothes and hair:
You can already have G9 wear G8F clothes and hair via autofit, the base G9 includes autofit clones for earlier Genesis figures. If you want batch converter, there are these:
If you want to autofit G9 clothes back to G9F you will need these (or make a clone yourself): https://www.daz3d.com/mmx-genesis-9-clones-for-all
For batch conversion there's this: https://www.daz3d.com/rssy-clothing-converter-from-genesis-9-to-genesis-8
Skins:
To use G8F skins on G9 there are 2 options:
It's also possible to convert textures manually, here's a tutorial: https://www.versluis.com/2022/11/converting-skin-textures-for-use-with-genesis-9/
To use G9 skins on G8F there's this: https://www.daz3d.com/genesis-9-uvs-for-genesis-8-and-81-female (similar system as the legacy UVs for G9)
Morphs :
There are two converters available to convert G8F morphs to G9:
Both have their strengths and weaknesses. A lot of people seem to like the first one better.
It's also possible to do it manually, here's a tutorial: https://www.versluis.com/2022/11/how-to-convert-genesis-8-characters-to-genesis-9-using-the-fit-suit-method/
That's excellent, thank you very much. I'm piecing together a strategy around this now. Also wondering if there are pose converters between G8 and 9, I'll have to look later.
There are quite a few options for poses:
Free ones:
Commercial ones:
The G8F/M->G9 pose transfer I did at Rendo (second freebie in Leana's list) is also available on this forum (here) and will eventually be paired with a G9-G8FM convertor. However, I'm having so much difficulty enjoying G9 that I've started a couple of times and stopped after getting not very much further. It will happen, unfortunately, looking at how busy I am this year with real life, it'll be a struggle to complete this side of 2025. Must admit I don't feel a convertor is complete until you can go back to the origin character to check the conversion.
Regards,
Richard
Thank you! I feel so foolish, I already own Zevo's pose converter. Must have bought it a while back and forgot.
