Show All Products Owned
It would be awesome to have a "show all products owned" option WITH the images.  I would love to scroll through my product owned library without having to click each item to see what I have.
  • AtiAti Posts: 9,208
    Visit http://3dwishlist.com/bookmarklet and use the second bookmarklet.
  • DAZ_RawbDAZ_Rawb Posts: 817
    As a side note, if you are using 4.9 and logged in to Daz Connect you can see all products that are owned in the Smart Content pane, just select the product tab and click on "All". You may have to uncheck the box at the bottom that says "Filter By Context" because otherwise it would just show you all of the products that you own that are compatible with your currently selected item.
  • barbultbarbult Posts: 27,632
    DAZ_Rawb, is there a way to filter the list of products with the search box? It doesn't work the way I expected. I have the Smart Content Products tab and enter a string in the search box to filter down to products with that string in the name, but the results don't show products with that string in the name. I can't figure out what that search is doing. If I what to see all products with "Horse" in the name, how do I do that?
  • R25SR25S Posts: 595
    edited January 2016
    It is very easy. Go to Smart Content, Product Tab; select "All" at bottom and in the categorys and type in your search in the searchbar
    559 x 908 - 129K
    Post edited by R25S on
  • AaronHAaronH Posts: 79
    I don't have those filters at the bottom.  I saw them briefly after the update.  I went looking for them to give the new updater a try with the new stuff i bought and can't find them.
  • fixmypcmikefixmypcmike Posts: 19,735
    Make sure you have "Products" selected at the top left and not "Files".
    Notice that it shows products that don't have horse in the name as well as ones that do. It is not a product name search. Something else is going on. Is it searching file names of files inside the product?
    I believe it searches for filenames and any tags on those files.
    i found them thanks ,now i'm waiting for the new stuff i bought to show up.  DOes it only come through if it's bought within the app or does it come up when it's bought though the site as well?
    It should still show if you bought it through the website, but I understand there've been delays in it showing for some people.
    Thanks Mike i'll check it out in the morning.
