Animal World Bear Eye Issues
Hello there. I'm kind of new, so forgive me if I am missing something very obvious or doing something daft here.
I'm using the  Animal World Bear body and textures with Victoria 4.2. Every time I try to render this character, the eyes are really bright red.
Anyone have any idea what might be happening?
830 x 702 - 1M
  • Which application are you using, and which render engine?
    I'm using Iray with Daz Studio 4.8.
  • OK, those are older Poser items - I can't recall if they come with DS material settings but they will be for 3delight if they do. What you migth try doing is selecting the eye surfaces in the Surfaces pane, manually applying the Iray Uber Base (should be available in the presets tab under Shaders>Iray) and copying across the settings, other than maps, from the optimised Genesis 2 eyes
  • Oso3DOso3D Posts: 15,125
    What I often do in cases like this is get a Genesis 2 figure with appropriate iray materials, convert the Genesis to Iray Uber Base, then check what the maps are for Genesis, copy stuff over from Genesis 2, and then change the textures to the appropriate maps.
    A little labor intensive, I suppose, but maybe 5-10 mins.
  • Thank you to everyoned who chipped in, I finally managed to get him working. This was the one that did it.
