Organizing favorites into sub-categories
Hi, is there any way to organize the favorites into different sub-categories please? Or a commercial product that allows you to do so? Thanks!
  • NorthOf45NorthOf45 Posts: 5,896
    Do you mean the menu Favorites? You can create sub-folders when adding them in the first place. If you want to do it later, use the Customize dialog (F3, or Window->Workspace->Customize). Go to the right side, click on Menus. Expand the Main Menu, where you will find Favorites. Right-click to add Submenu.. which will immediately add a new entry in edit mode. Name it as you wish. You can drag items into the submenus from existing entries, or add new items directly into them next time.
  • crosswindcrosswind Posts: 10,247
    edited September 2024
    Or... OP means Favorites category in Smart Content ? If so, yes, check the attached screenshots 1 ~2
    But the default "Add to Favorites" action can only add the asset item(s) to the root category of  "Favorites". Then you have to re-assign the item(s) to its sub-categories that you created, by using "Categorize..." action as usual. (ss 3)
    There's no commercial product for helping with doing these, and in fact you don't need any. Just do it with the standard functions in DS...
    495 x 1294 - 150K
    495 x 1294 - 109K
    697 x 986 - 103K
    Post edited by crosswind on
