Kit bashing armor. Is there such a thing?
Anyone know of any product that allows you to kit bash armor? I've purchased a few armor clothing off the Daz store and while most of them are nice, sometimes I feel like they could use extra flourishes or details. (I've tried mixing clothing together and sometimes that produces decent results)
I guess the closest thing for comparison is this sci fi kit bash:
http://www.daz3d.com/nurnies-greebles-parts-and-pieces
    Nope...no armor kit like that, that I know of.
    A lot can be done with things like bump/displacement/normal maps, too...I've etched steel armor and embossed leather with displacement maps and had nice results.
  • There's the Piecemaille Armor Kit for M4. I don't know of anything more recent.
  • srieschsriesch Posts: 4,243
    edited January 2016
    There is nothing stopping you from using pieces of armor from many different sets.  Granted they won't all line up nicely into one suit of armor, but you could use gauntlets from set 1, bracers from set 1, shoulder thingies (pauldrons?) from set 3, a chest piece from set 4, boots from set 5, etc. if there is either a bit of a gap between them showing skin (common in the partially armored styles often seen in art). And if you were willing to eliminate the material that came with them and use a shader, or modify the material, you could have pieces that overlap but it might still work and just look like random bulges or decorative bits because all the pieces are one material.  Perhaps one could use a few primitives, spikes, cloth wrappings, or other objects to hide any flaws where two pieces don't join nicely.
    Post edited by sriesch on
  • ghastlycomicghastlycomic Posts: 2,531
    If you get yourself a modelling program anything can be kitbashed.
  • JeremyDJeremyD Posts: 265
    Aw. I had a feeling it didn't exist.
    But ya I've been searching for pieces to glue on
  • Pack58Pack58 Posts: 750
    Bodysuits with mail/leather/quilted linen (or just flat black) textures/shaders can be a convenient way to cope with gaps.
    Also look for second skin and even MR's for leather, mail or carbonfibre.  Check out some of the texture sites.  Even tiling textures can be applied to mat zones.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,484
    edited January 2016
    You can just parent objects to bones, things like skulls, jewels etc as armour rigid
    Use a chainmail undersuit
    can resize sheilds and things too as bits, look in your props
  • Oso3DOso3D Posts: 15,115
    Yeah, what I normally do for rigid armor is I parent the breastplate to the chest, adjust to fit. Possibly also shoulder and hip armor -- basically, anywhere joints are very flexible and liable to turn armor to putty.
    Then I either use a bodysuit, geoshell, or even just retexture the actual body to make a chain layer (which, after all, is fairly realistic).
    edited January 2016
    And doing that, you can with a little fitting work put just about any armor on anyone...I've used an old, old freebie armor on G2M that way.  And if you are using 3Delight, 3dcheapskate has a tiling texture set that does wonderful chain and scale for the under suit.
    http://www.sharecg.com/v/54624/related/11/Poser/Tileable-Mail-Textures-1-And-2
    http://www.sharecg.com/v/55332/related/11/Poser/Tileable-Mail-Textures-3-6-Kusari
    http://www.sharecg.com/v/60179/browse/11/Poser/Tileable-Mail-Textures-7-9-Scale
    Also, parts of the M3 Norman set do autofit Genesis and Genesis 2
    http://www.sharecg.com/v/27632/poser/M3-Normans-Outfit
    Post edited by mjc1016 on
    that's some good looking chain mail! thanks for sharing
