DAZ Store Products
If the DAZ store says a product is for DAZ Stiudio, is it specifically saying it's not compatible with 4,8 or 4.9? Or is it that they just haven't gotten around to changing the verbiage?
Usually I notice most products labeled this wayhave been Genesis when I see this.
Thank you
    edited January 2016
    I suspect that it would mean that it can be used on legacy versions, as well as the up to date versions of DS.
    Post edited by Chohole on
  • LeanaLeana Posts: 13,514
    edited January 2016
    "Daz Studio" only means they were made for older versions of DS. I think they started using 2 different tags when they introduced .duf format in DS 4.5 since earlier versions can't use that format, but it might have been with DS4.
    Content tagged "Daz Studio" only should work fine in newer versions, but for example you won't have Iray materials.
    Plugins tagged "Daz Studio" only may not work with newer versions at all (for example some older Dreamlight plugins work in DS 3 only), so check the description or ask in the forums before buying.
    Post edited by Leana on
