Help with render devices.
Hi, Im using Daz 4.6 Photoreal engine. I have a GT 430 gfx card, When I select only it as a render device and try to render, the window opens and then it just stops. I have to also check cpu to get it GT430 is compatible with iray, It just seems like its being blocked out or something? is there something extra I need to do to get it to work by itself? I cant tell if its even working at all with both checked. any help is appreciated, Window 7 x64
Um...430s don't have much in the way of memory...so in all likelihood, it won't be used, because all but the most basic scenes will surpass it's 1 GB of memory.
