My outfit can't change materials!
I have the chirstmas outfit of genesis 8 Fluffy Outfit for G8F - Daz Content by rendorgal (renderhub.com) but I can't change the materials!
2024-08-22 11:36:15.992 [INFO] :: Prepare asset load (merge): /People/Genesis 8 Female/Clothing/Rendorgal/Fluffy outfit/Materials/Base Color Violet.duf
2024-08-22 11:36:15.992 [INFO] :: Locking viewport redraw...
2024-08-22 11:36:15.992 [INFO] :: Viewport redraw locked.
2024-08-22 11:36:16.139 [INFO] :: Native format content directories: 3
2024-08-22 11:36:16.139 [INFO] :: Poser format content directories: 3
2024-08-22 11:36:16.139 [INFO] :: Other import format content directories: 0
2024-08-22 11:36:16.139 [INFO] :: Begin asset load (merge): /People/Genesis 8 Female/Clothing/Rendorgal/Fluffy outfit/Materials/Base Color Violet.duf
2024-08-22 11:36:16.142 [INFO] :: Determining missing assets...
2024-08-22 11:36:16.142 [WARNING] :: Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
2024-08-22 11:36:16.142 [INFO] :: Error loading asset: H:/My DAZ 3D Library/People/Genesis 8 Female/Clothing/Rendorgal/Fluffy outfit/Materials/Base Color Violet.duf
2024-08-22 11:36:16.142 [INFO] :: Operation failed
2024-08-22 11:36:18.827 [INFO] :: Unlocking viewport redraw...
2024-08-22 11:36:18.827 [INFO] :: Viewport redraw unlocked.
  • crosswindcrosswind Posts: 10,249
    edited August 2024
    They're hierarchical material preset which will check the if the node name of the figure is correct... so what Genesis figure are you using, G8F or G8.1F ?
    Post edited by crosswind on
  • Tonio2bcoolTonio2bcool Posts: 5
    edited August 2024
    both but mosty G8F
    Post edited by Tonio2bcool on
    Oh... so, select your figure, goto menu: Eidit - Figure - Scene Identification..., find Node Name field.
    If you're using G8F, change Node Name to Genesis8_1Female Accept.  Then load the H.Material Presets, see if they work.
    edited August 2024
     Actually I deleted the number in the node name!
    I don't understand what you mean ~
