How to adding bones to strand based hair?
aserwaserw Posts: 1
[How to adding bones to strand based hair?] It's not the same as a mesh hair.
  • crosswindcrosswind Posts: 10,358
    The SBH you made with SBH Editor ? If so, you have no way to add bones to it no matter with Joint Editor or Transfer Utility. You have to generate PR hair firsly then export it to a static mesh OBJ. Import the hair mesh then rig it. But after these process, the hair is not an SBH anymore.
  • lilweeplilweep Posts: 2,883
    If you cant do with bone weights, you could perhaps add a bone as a driver/controller of a morph for the hair, but at that point why not just use the morph from parameters rather than bone?
  • aserwaserw Posts: 1
    edited August 2024
    Post edited by aserw on
    edited August 2024
    You have this hair and want its bangs like that ? or you want the bangs of other SBHs like that ?
    If you mean the former, there're bang curl morphs on this hair, just dial them.  If you mean the latter, Daz users can only deform SBHs by using d-Former (move, scale, rotate...)...
    Post edited by crosswind on
