Default dForce settings on the new Kaede Kimono
TirickTirick Posts: 236
edited August 2024 in The Commons
Just some advice, if you are struggling as I did initially. The default Bucking stiffness is far too high imho for this set. It produces very odd draping on the sleeves. I turned mine way down to 15% (from 80%) and had much better results in simulation. ymmv, but some adjustments are absolutely needed out of the box, unless you want very stiff and non-simulated sleeves.
https://www.daz3d.com/bw-dforce-kaede-kimono-outfit-for-genesis-9
I attached my settings, where I further tweaked a few things, but you can see the difference, which was largely from the bucking change.
This is using a 2-second transition and 2 second stabilization, as I initially thought it needed more stabilization to drape.
Tirick
714 x 863 - 349K
802 x 823 - 899K
718 x 862 - 336K
822 x 823 - 925K
Post edited by Tirick on
  • ArtiniArtini Posts: 10,962
    Thanks for posting. dForce items are sometimes tricky to use.
