Why doesn't Daz Studio 4.9 show what texture is applied in the surface tab?
Kev914Kev914 Posts: 1,143
The default figure I have loading is Genesis 2. I thought the default texture that loaded was Bjorn. To be sure, I went to the surface tab and selected the torso and then I clicked on the dropdown next to diffuse. It brought up a list but nothing was checked. In 4.8, the texture that was applied would be checked. As a check, since the Bjorn texture used to be the default as near as I can recall, I added the gens and applied the Bjorn texture, but it did not match the figure. In the list that comes up in the surface tab, the were a whole lot of Philip textures loaded but nothing checked. I figured that must be the texture that is applied, but when I applied the Philip texture to the gens, it did not match either. I did not see the names of any other character listed.
So how are you suppose to know what texture is applied, if you didn't apply it yourself?
Since there were a whole lot of Philip textures loaded and I didn't apply them, that must be the texture that is applied. But if so, then why don't the two textures match (body and gens)?
  • SimonJMSimonJM Posts: 6,100
    If you applied them manually there may be a mismatch in shader, probably Daz standard vs AoA?
  • Kev914Kev914 Posts: 1,143
    OK. I was looking at the Opacity. You have to dig down to the diffuse setting and then when you click the drop down next to diffuse, it will bring up a list and then it will show you which texture is being used. (There will be a check mark next to it.
    It appears that the default texture being used on Genesis Male 2 is the Philip texture. As I recall, there is something wrong with the icons for loading the Philip gens materials. There was a thread about it somewhere. I couldn't find it. I had to do something and then save out my own icon to get one to work, but I don't remember what I had to do.
    Anyway, I understand how it works now.
    Wish they would fix the icons for Philip gens though so they would load properly.
