Posing multiple figures in a linear line up - Solved
ArtAngelArtAngel Posts: 2,096
edited August 2024 in The Commons
Seeking any tips on populating/posing multiple different figures in a linear line up. I am trying to achieve a lineup of about 50 figures. Seven semi-decent-detailed characters, wearing different outfits, plus instances of characters. I am trying to make a wavy shaped line, like an S shape. Prefer it not be a straight line. I'm okay with doing multiple renders, just not twenty of them. Appreciate any thoughts, because mine are not working out. sad
Post edited by ArtAngel on
  • crosswindcrosswind Posts: 10,344
    A straight-forward go > use this product https://www.daz3d.com/flockit which can help you make it pretty quickly.
    Or a free way > use Align plugin in DS. That'll take more time...
  • ArtAngelArtAngel Posts: 2,096
    Thanks a ton! I will try both these methods. Just added Align as a pane. Opening Zip file to see if FlockIt tutorial PDF exists. Seems not. I'll install it and give it a whirl.
  • felisfelis Posts: 6,593
    edited August 2024
    If you don't mind doing it by hand, you can do it fairly easy by using a guide.
    Here is an example, although only with 20 +1.
    1500 x 1500 - 3M
    Post edited by felis on
    I don't, and thanks for sharing. I do want distinctive characters, and I do need precision placement either within Daz or via multiple renders alteried in post-work. You nailed exactly what I need. If I do similar and in PS duplicate, flip, warp and blur into the nothingness of infinity, it should be perfect. Maybe to save time I'll dress everyone alike and overpaint outfits in PS.
    I used, as I said a guide, as can be seen here.
    If you want it, it is attached as an obj file. Must be imported in scale 10000%.
    1500 x 1500 - 3M
    zip
    zip
    S_curve.zip
    2K
    Thanks a bunch. Makes the process so much smoother and precise. Please check your messages.
