parameters controls are gone from the interface.
I have Studio 4.8 and somehow the parameter controls have disappeared from the right hand side of the interface and I can't get them back. There used to be two rows of controls and now there is only one row, with the RH side of parameters controls (xyz etc.) are gone. How do I get them back? Thanks Sherrie (drifterlee)
Is the pane closed? if so go to Window>Panes(Tabs)>Paarmeters. You can also simply reload your layout - Window>Workspace>Select layout - though that's a bit drastic if you can just reopen the pane.
