Please, please help with a GenX2 question.
I have read every tutorial and manual on GenX2, and can't find the info I need.  I want to transfer the head morphs from a M4 morph over to G2M.  Every time I do, the transfer goes all the way through, but when I slide the slider, nothing changes on G2M.  Could someone please help me try to figure out if I'm doing something wrong or if its even possible to transfer the morphs I want?  I have included a picture of M4 with the morph I want to transfer.
1306 x 606 - 309K
  • HavosHavos Posts: 5,699
    After you have transferred the morph, did you remember to dial M4 into G2M? GenX2 creates a delta of the M4 morph, and if the morph you are transferring is only slightly different from M4, you will not see much difference when you dial it into G2M alone.
  • BoorsmanBoorsman Posts: 283
    Yes I did.  The only change is that G2M tuned into M4.
    Describe the steps and options you went through to transfer the morph. Did you use "Single Morph Only", and did you remember to select all values with non zero value after injecting your M4 morph?
    I loaded M4 then loaded the morph.  I always check to make sure the morph is actually applied and it was,  I then click on Select/ " Get values from figure in scene", select/ "transfer on for all non-zero values".  I always select "Single Morph Only" and then I click on "Transfer".  I know I successfully transfered a head morph from another character from the same artist, I just can't remember how.
    Ok, I normally do not even bother to load M4 into the scene. I select M4 as the source and then click Apply Pose. After that I select "Transfer on For All Non-Zero Values". Then you can check in the Morph panel that there is a tick against all the morphs that will be applied and their values. Only after this will I click on Transfer. Have you checked that the expected morphs have been ticked before you transfer?
    OMG!! That worked!  Thank you so much for your help.  I'm going to copy and paste your last post into a text document and save it for future reference.
    You're welcome, I am happy to help
    One last thing to add, the M4 you load into GenX2 should be one with all the morphs injected. I normally load an M4 normally into Daz Studio, and then powerloader injects all the morphs I have for M4. I then export M4 as a CR2 and load this into GenX
