How to Add Images to Post Body
I know how to attach them, but I've forgotten how to display them in the body as many do in the contest or the Render Your Buys threads.
(Optional: insert Search Rant)
  • Attach the image to the post, post it, to be safe refresh the page.
    Right-click on the image thumbnail and copy the link (not the image Link, which will get you the tumbnail only).
    Edit your post, put the cursor where you want the image, and click the add image button at the top. Paste the copied URL into that, hit tab so the size fields refresh, if the width is greater than 800 set it to 800 - otherwise the image will get squished non-uniformly - and post the edit.
  • frank0314frank0314 Posts: 15,114
    You can also host your image elsewhere and then you would use the image icon above, to the right of the flag. Paste in your URL, then go down and adjust the width to 800 if the image is larger than that.
