3Delight - Searching for good stone/brick/concrete shaders/textures
cosmo71cosmo71 Posts: 3,609
Hello, I am still rendering in 3Delight and I am looking for some some good stone / brick / concrete / wood / ground shaders/textures for 3Delight. There are some here at the store but I do not know which is good and which is not so good, can someone help me?
  • cosmo71cosmo71 Posts: 3,609
    BTW, my intention is not buying a new machine just for rendering images in Iray, so.
  • MegonNoelMegonNoel Posts: 385
    Have you tried Pimp My Prop? I have it and I can say it's superb. Definitely one of my favorites.
  • LinwellyLinwelly Posts: 6,070
    Also there are these https://community.renderman.pixar.com/article/114/library-pixar-one-twenty-eight.html for free You will have to load them within the surface tab of your prop you want to retexture but they come with bump and normal. Ther are some of everything you asked for.
    As far as 'raw' tiling textures go, Nobiax/Yughues has a vast colletion of them, including all sorts of stone/brick...yes, they need to be manually applied and presets made, but...
    http://www.sharecg.com/pf/full_uploads.php?pf_user_name=yughues
    Is it for 3Delight or Iray, I need 3Delight shaders and textures (materials)
    It's for 3Delight...
    edited January 2016
    Yes, it's for 3Delight. Sorry, I should have been clearer about that. I only use 3Delight as well since I prefer the look of it over iray. It's a great set and has a lot of different shaders, primarily for buildings (great for walls, floors, etc) both interior and exterior. It has things like wood, cobblestone, brick, plaster, concrete, etc.
    Post edited by MegonNoel on
