duplicate formula in one morph
I changed the position of the bones and saved it but then I started getting a message about a duplicate formula
log
Previous:
File: E:/array/Software/DAZ3D/libarty/save/data/Daz 3D/Genesis 8/Female/Morphs/Zeni1Agent/HF/HF.1 Vroid Head.dsf
Owner: Genesis8Female
Input URI: Genesis8Female:/data/Daz%203D/Genesis%208/Female/Morphs/Zeni1Agent/HF/HF.1%20Vroid%20Head.dsf#HF.1%20Vroid%20Head?value
Input: HF.1 Vroid Head
Output URI: tongue01:/data/Daz%203D/Genesis%208/Female/Genesis8Female.dsf#tongue01?end_point/x
Output: xEnd
Duplicate:
Output: xEnd
The duplicate is in the same file and I don’t know how to rewrite it.
I tried saving as new Morph Asset and as Save Modifier Asset
but it didn't help
If you run ERC Freeze twice in succession, without first using ERC Bake to turn the links into local settings, then you will get the issue. You have lost whatever you did on the second freeze, but if you now bake the links (set the cotrnoller to 100%, then right-click on the links in the Property Hiearchy pane to bake them) you should be able to add/adjust settings and redo the freeze, after which you can resave the non-suplicated settings.
