Displacement workflow with Carrara
FettbemmeFettbemme Posts: 319
edited August 2024 in Carrara Discussion
There have been numerous example scenes of greeble-like cities.
Carrara has a very powerful displacer more powerful than Cinema 4D.
In this small clip I show you how you can use any texture you like to generate cityscapes or circuitboards and the like.
I used for the Texture the free program JSplacement which is (was) very well known.
In case you want to try this for yourself.
The first render is with the Phong Tesselation Plugin and the render below is without.
So much to shooting the "messenger" …
with Phong Tesselation Plugin
without Phong Tesselation Plugin
zip
zip
JSplacement_Carrara_Displacement.zip
5M
1920 x 1080 - 303K
2000 x 844 - 1020K
2000 x 844 - 933K
Post edited by Fettbemme on
  • Steve KSteve K Posts: 3,538
    Thanks. I've been using Carrara for (mumble, mumble) years and have never tried this.  Still finding new features ... yes
  • ProPoseProPose Posts: 550
    edited August 2024
    I actually learned this trick from one of the lessons from Phil's Realism Rendering tutorials quite a while ago. Using disp. maps to create props and stuff.  Just plug in a disp or hight map in the terrain editor,  change the terrain shader to multi-chanel in the shader room, add the corresponding textur maps, and you get some pretty good looking floors, wood, tileor stone,  and walls like brick or wood.  I generally use a 1K disp map to get good results, 2K at the most.   Any bigger like 4K or 8K the resulting terrain is humungus in file size and slows down performance. Use 1K or 2K disp map the generate the terrain and 4k or 8K for the color and bump.  If you don't have a disp map, you can use a normal map instead which works not to bad.
    Post edited by ProPose on
  • FettbemmeFettbemme Posts: 319
    I'm just amazed how good the Carrara Displacer really is and that without Plugins.
    In the example I used an 8K displacement map..
  • StezzaStezza Posts: 9,273
    very cool is Carrara smileyyes
