Problem loading HDRI from smart content/content library
Whenever i try to change HDRI from smart content or content library (for exempla go "Render Settings>Iray and try to loat any file ike DHTDR-MauiA) it shows progress bar but nothing happens afterwards. The Enviroment map in render settings is still set to default "ruins" one. What am I doing wrong?
    edited July 2024
    That sounds wrong. I have that file and it should show a dialog box straight away asking if you want to save the current scene before it replaces it. Once you hit no it should complete within a few seconds.
    Go to Help->Troubleshooting->View log file, delete the contents of that file (back it up elsewhere if you want) and save it. Then run that command again and when it stops doing something and/or after 30 seconds or so view the log file again and see if there is anything in there they may explain your issue.
    This is what I get from running it
    2024-07-30 21:49:10.825 [INFO] :: Prepare asset load (open): /Light Presets/Iray HDR Outdoor Environments/DTHDR-MauiA.duf
    2024-07-30 21:49:10.825 [INFO] :: Locking viewport redraw...
    2024-07-30 21:49:10.825 [INFO] :: Viewport redraw locked.
    2024-07-30 21:49:10.875 [VERBOSE] :: Native format content directories: 3
    2024-07-30 21:49:10.875 [VERBOSE] :: Poser format content directories: 3
    2024-07-30 21:49:10.875 [VERBOSE] :: Other import format content directories: 3
    2024-07-30 21:49:10.875 [INFO] :: Begin asset load (open): /Light Presets/Iray HDR Outdoor Environments/DTHDR-MauiA.duf
    2024-07-30 21:49:10.885 [INFO] :: Clearing the scene...
    2024-07-30 21:49:11.066 [INFO] :: *** Scene Cleared ***
    2024-07-30 21:49:11.066 [INFO] :: Determining missing assets...
    2024-07-30 21:49:11.067 [INFO] :: Setting textures...
    2024-07-30 21:49:11.506 [INFO] :: Scanning for addons...
    2024-07-30 21:49:11.506 [INFO] :: Creating node geometry...
    2024-07-30 21:49:11.506 [INFO] :: Resolving legacy figures...
    2024-07-30 21:49:11.506 [INFO] :: Processing scene data...
    2024-07-30 21:49:11.511 [WARNING] :: QColor::setRgb: RGB parameters out of range
    2024-07-30 21:49:11.512 [INFO] :: Sorting property groups...
    2024-07-30 21:49:11.512 [INFO] :: Setting up follow targets...
    2024-07-30 21:49:11.512 [INFO] :: Setting current camera...
    2024-07-30 21:49:11.512 [INFO] :: Finalizing scene data...
    2024-07-30 21:49:11.512 [INFO] :: Finished asset load (open): 0m 0.636s - /Light Presets/Iray HDR Outdoor Environments/DTHDR-MauiA.duf
    2024-07-30 21:49:11.542 [INFO] :: Unlocking viewport redraw...
    2024-07-30 21:49:11.542 [INFO] :: Viewport redraw unlocked.
    2024-07-30 21:49:12.700 [INFO] :: Loaded image: DTHDR-MauiA.hdr
    Post edited by SofaCitizen on
