Does the glass of this window have any magic of refraction?
I rendered an image of the outside of the room looking into the inside through a window.
The first image, before rendering
The second image, the hidden wall, the rendering, everything is normal, everything is as I expected
The third picture, which does not hide the wall, render, and reflect the scene in the window, does not belong to the scene that can be seen from a normal Angle.
I don't understand, for the first time in the DAZ encountered this kind of enchanted window
2252 x 1712 - 2M
2223 x 1682 - 5M
2197 x 1664 - 3M
  • GordigGordig Posts: 10,808
    Looks like regular refraction to me, the the IoR might be a bit too high. Where do you have it set now?
  • kyoreonakyoreona Posts: 222
    thank you ! I found it ! surface,[refraction index] ,set it to 1,everything goes right !!
  • felisfelis Posts: 6,530
    Refraction index of 1 is air.
    I think your problem might be that you should have set thin film to On, assuming that your glass is a thin plane, and not with volume.
    I'm sorry, where can I find the options you mentionedsurprise
    edited July 2024
    Felis misspoke; you're looking for thin-walled, not thin film. It's under Volume:
    490 x 426 - 31K
    Post edited by Gordig on
    Bad memory blush
