Geo-grafts not following morphs after reload
bwise1701bwise1701 Posts: 254
Hi all,
I'm having a problem where I do a Goz out to Zbrush do a morph and push it back to Daz. All good - dial in the morph and it works fine and my geo-grafted geometry follows along with the morph. Happiness. I save the file, quit, bring it up later and no the morphs is still as it was but the geografted geometry is no longer following with it. It's still grafted correctly in that it's edge vertices meet up with tht parent subdiv find but the distortion on the base mesh is no longer distorting it. If I recreate - out to zbrush and back with a new morph - all without closing the session it works again - but then on save & reload same thing - morph do longer distorts geo-graft.
Any ideas?
thanks
Post edited by bwise1701 on
  • Is the morph set to auto follow?
  • bwise1701bwise1701 Posts: 254
    Yep.
  • You may need to save the morph with the geograft as well as with the main object.  So when the geograft morphs correctly before saving, export it then reimport it using the Morph Loader, then save it.  When reloading it the saved morph on the geograft will kick in when you apply it to the main object.
