Error Message on Materials dForce Molly Hair for Genesis 9
I can not change the materials on above mentioned hair by Propschick. A reinstall didn't fix the problem.
https://www.daz3d.com/dforce-molly-hair-for-genesis-9
Any ideas or help would be appreciated, the Log File displays the following errors:
2024-07-19 10:20:10.525 [INFO] :: Begin asset load (merge): /People/Genesis 9/Hair/Daz Originals/Molly Hair/Materials/Iray/Molly Hair Auburn.duf
2024-07-19 10:20:10.843 [INFO] :: Determining missing assets...
2024-07-19 10:20:11.164 [WARNING] :: Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
2024-07-19 10:20:11.164 [WARNING] :: Error loading asset: F:/Content Library/People/Genesis 9/Hair/Daz Originals/Molly Hair/Materials/Iray/Molly Hair Auburn.duf
Operation failed
  • GordigGordig Posts: 10,798
    Do you have the hair on a G9 character, and do you have the character selected?
  • LeanaLeana Posts: 13,501
    edited July 2024
    That error message means that you're using a hierarchical material preset and don't have the right item selected.
    My guess would be that the hair is made of multiple parts, hence the hierarchical preset. You probably need to have the figure selected and not the hair.
    Post edited by Leana on
  • crosswindcrosswind Posts: 10,249
    You can select any of the nodes shown in the attached screenshot, then apply H.Mat preset, it should work.
  • LauritaLaurita Posts: 288
    Sadly none of this works for me. Do you have your Content Library in it's default location? Because I don't, maybe that's the root of my problem.
  • Richard HaseltineRichard Haseltine Posts: 111,353
    Is the hair parented to the figure?
    Oh boy, silly me. I was trying to change the Materials either fitted to G8 or unfitted. I didn't expect it to work only when fitted to G9.
    I addressed that possibility, and you seemingly ignored it.
    If so, select your G8 figure, go to menu: Edit - Figure - Scene Identification, change Node Name to Genesis9...
    or parent the hair to a Genesis 9, if you have one loaded, while leaving it fitted to Genesis 8/8.1
    edited July 2024
    Oh, ho ~ We have to think about any possibility... I guess you probably directly parented this SBH to G8's Head node rather than using Auto Fit... If so, you can firstly parent the hair to G8's root node, change hair's Node Name and apply H.Mat presets. After everything is done, parent it to G8's Head node...
    Or, you go for Richard's solution.
    Post edited by crosswind on
    Sorry for that, I simply overlooked it,
