Alternative DAZ config file?
geoff6
Hi all, I run two versions of Daz, the 64bit 4.8 version and a 32bit 4.6. I only use the 4.6 for lip-syncing. However, the configuration of windows within each version is different between the two and so differences are transferred which is a bit of a pain. Presumably, there is a config file somewhere that records the windows and their positions so is it possible to have separate config files for each version? I assume this would require pointing each version of DAZ to it's repective configs so where do I go in DAZ to achieve this if indeed it is possible at all?
Thanks in advance,
G
SAve your 64 bit layout as a layout (Window>Workspace>Save Layout As...), then switch to the 32 bit version, tidy the layout up as desired and save that in the same way. Now you can use Window>Workspace>Select Layout to swap between them.
Once again, thank you Mr Haseltine. You've made it all so clear!
G
