Stange Skin Indentations after clothes removal.
raven449raven449 Posts: 48
After removing the Zero One Everyday shorts and top, I get these skin indentions left like the clothes are still there, even though the clothing is deleted. Does anyone know how to fix this? Thanks
1215 x 2160 - 217K
Post edited by raven449 on
  • GordigGordig Posts: 10,799
    Look under Currently Used in the Parameters pane, and you should see some morphs associated with Zero One, like "skin indentation" or some such. Zero those out.
  • raven449raven449 Posts: 48
    edited July 2024
    Found it under Squeeze Shorts and Squeze Top. Thank You So Much!!  Was driving me nuts! :)
  • crosswindcrosswind Posts: 10,249
    Those are morphs that the vendor made to show skin pressures (creases) on body when clothing fit on the figure. You can check ReadMe, and load Wearables with or without special morphs as you wish, and/or Zero morph properties as Gordig said.
    1034 x 958 - 173K
    edited July 2024
    Ahh yes, well like always when in doubt, read the manual. And I didn't :)
    The Currrently Used sliders was something I did not know, so good tip there anyway.
