V4 Nightmare
I own all 3 generations of Genesis figures. G1F has the exact V4.2 map that I need to use with G2F.
I have spent ALL day trying to get this ONE thing done.
How to I get G2F to use the G1F default set of UVs (=V2)?
I am only presented with the choice of Base Female (G2F) and V5, which I don't own or want.
    Genesis and Genesis2 only include UVMaps going back one generation — Genesis can use V4/M4/K4 textures, G2 can use Genesis textures. (Genesis3 uses a completely different UVMap, getting any earlier textures on to them is... complicated.) If you want to expand this only-one-generation ability, you need an expansion set like the onne Mike noted.
  • No workee.
    I purchased, downloaded and installed Victoria 4 for Genesis 2 Female.
    I open DS 4.9, load G2F (Content Library > DAZ Studio Formats > My DAZ3D Library > People > Genesis 2 Female {double-click})
    I ensure G2F is selected in Scene.
    On the Surfaces tab, I search for UV, then select "Victoria 4" as UV Set. (My other selections are Base Female and Victoria 5.)
    I then go to Content Library > Poser Formats > My DAZ3D Library > Pose > [product skin material] double-click
    Material is not applied.
    I drag material into the figure's window.
    Assumption: Pilot error.
    WTF am I doing wrong?
  • You need to apply the materials in Poser Format to Victoria 4 or, failing that, Genesis and then File>Save as>Materials Preset... The saved Materials preset should then apply to G2F corectly.
  • ArkadySkiesArkadySkies Posts: 206
    edited January 2016
    Edit:
    So I was doing it the hard way for no reason. Glad to know.
    Post edited by ArkadySkies on
    You don't need to do it one material zone at a time.  As Richard said, load it on V4 (or G1 if you don't have V4) and save as a material preset, then you can apply the new material preset to G2F.  G2F can recognize the old material zone names used in prior models if the material preset is in duf format.
  • From the Victoria 4 for Genesis 2 Female product page:
    note: Due to a limitation in how DAZ Studio handles presets, only material presets which are in DUF format can be directly applied. Any existing material presets must be re-saved in DUF format from the original Victoria 4
    edited January 2016
    Using this free script, you can use whatever file type you like. pz2, dsa, duf, etc and materials will change. Just remember to copy the torso surface to G2F's new ear surface that V4 didn't have.
    http://www.sharecg.com/v/70109/browse/8/script/genesis1-surfaces-for-g2f-and-vice-versa
    You'll still need the V4 for G2F product mentioned previously by Mike for the UVs.
    Post edited by Lissa_xyz on
    edited January 2016
    I think you're doing it wrong. You are still not applying the "V4 for Gen 2 UV". You are picking the original V4 UV. On my installation, th eV4 for Gen 2 UV is found in: People/Genesis 2 Female/ Materials / Victoria 4 for Genesis 2 Females. See the attached screenshot. Just double click when the G2F subject is selected.
    No workee.
    803 x 357 - 39K
    Post edited by fastbike1 on
    No workee.
    No, the problem is that the mat files need to be applied to Victoria 4, if available, or Genesis, if V4 isn't available, then saved as a Materials preset (File>Save as>Materials preset), then that file rather than the Poser Mat file needs to be applied to G2F.
